Lower unit problems: part deux
billsnogo
Well, after going to harbor freight to get a large set of snap ring pliers, I got the lower unit totally apart.
It looks like the edges on the clutch dogs forward side, and forward gear were worn down a bit. So nice to know when I get the new gears in I SHOULD be able to enjoy the boat...... if it is not winter by then!
I bought this gear set
http://cgi.ebay.com/ebaymotors/ws/e...0456158877&viewitem=&sspagename=STRK:MEWNX:IT
and sure enough, it appears the clutch dog, pinion, forward, and reverse gears are different :mad: Friggin A!!!
If I ever get this thing back together, I will post what snap ring pliers worked, gear puller, ect so the next schmuck who attempts this with a similar model will know what they need before diving in....... it takes way to long if you need to keep stop and go for tools/materials :(
billsnogo
Re: Lower unit problems: part deux
Here is the comparison of clutch dogs
Daviet
Any chance to return them since they are listed wrong?
billsnogo
Yeah, they are working with me on it right now, but will not get a for sure answer until tomorrow when they are in the office. They so far have been A+ with customer service :D
Hopefully I can get the correct ones quickly so I can see what else I need to put this bugger back together.
So far I think it is only
lower unit oil
gasket sealant
omc tripple guard grease
and a few hours, and lots of luck with the shift rod.....
