86 Johnson, 28 HP. After replacing seals and a new impeller, got the motor back on the boat, and all is fine. But, being the nervous sort, I'm wondering just what the lube capacity of the lower unit is. I've been through the repair manual (Clymer), and the motor manual and don't find it anywhere. It just sure doesn't seem like it took anywhere near as much as my 35 HP does. I'm relatively sure I'm fine--I added through the drain hole until the fluid came out the vent hole just like I've always done. But, like I said, I'm the nervous type and just want to make sure. I sure don't want to go through that lower unit again any time soon. Thanks in advance!
