stourm
- Joined
- Feb 21, 2009
- 48
Re: Lower unit question
BigB, I would be happy to email it to you but its 157 MB so not really a possibility. I will host it out somewhere though on a site and send you a link to where you can get it.
I have run into a snag though with my replacement. I can't figure out exactly how to get in there to the screw for the shift lever. I am assuming that you need to remove the screw that attaches directly to the long shift lever that runs from the lower unit up into the motor. The only thing I can find access to is that blue arm that stretches out to the side. Where the long rod itself comes up from the lower unit into the engine compartment seems completely inaccessible without removing a whole bunch of motor. Have any of you replaced a lower on one of these 140 Evinrudes that might be similar to mine? I assume that since most of you guys replace the waterpump every year that someone out there might have a good piece of advice for getting at that shift rod screw. Any help would be appreciated.
