Lower Unit Questions
fmanerchia
1973 85HP 4 stroke (85ESL73M). Put on a new L/U and had forward and reverse until it hit the water, then only forward. The shift rod connector was adjusted instead of the gear cable adjuster. Now it's out of whack. <br /> Can we find the correct depth on the shift rod by spinning the connector w/ needle-nose pliers one turn at a time (flat side facing forward) or should we drop the L/U? Which lube should be used? Would it be easier to get it adjusted right if it were installed while in gear? Up is reverse and down is forward? A local marina sold me this Johnson gear oil that was green, but I've always heard that it should use HiVis. <br /> I think that's all of the questions ,Thanks
