scott_maier
Thread starter- Joined
- Mar 16, 2009
- 124
Hello,
I've got two lower units for a 6hp, 1974 motor, one is basically junk and I am using it for educational purposes and possibly parts. The other I want to check out and make sure it is good to go. According to my manual there is supposed to be a spring and two detent balls under the clutch dog that you catch with your hand as the clutch dog is slid back. I didn't see the spring or detents on either of the two units I have. Is this normal or am i missing the parts?
My next question...both water pump housings have grooves on the inner surface where the impeller tips would be rubbing. The grooves look like rough lathe work. Is this normal for these water pumps?
Thanks in advance,
Scott
Thanks in advance,
Scott
