BigBassin78
Thread starter- Joined
- Aug 13, 2011
- 64
I have recently bent my prop shaft from a submerged strike. I bought a 91 E150EXEIS unit to swap with my 95 J150GLEOM.
First question is:
1 Is there any reason why these would not be able to swap parts between them?. Some parts that look identical have different part numbers in the explosion graphic on boats do t n et. Besides the upper drive shaft length they both look identical
2 Can I switch the upper drive shaft and shift rod, because that is the only thing stopping me from bolting this unit on to my motor.
3 Can I switch the upper shaft without pulling the prop shaft and gears out?
4 what are the chances that any shaft shimming will need to be done if i just replace the upper drive shaft.
thank you all for any help that you can provide!
First question is:
