lower unit refitting
gazzatop
Hi all
can any one help or tell me what i am doing wrong , i have removed the lower unit on my jhonson, replaced the impeller and now have problems with putting it back . all seams to go ok but there is a half inch gap between the lower unit and the bottom of the leg . i did not want to force it in. can anyone tell me if it just need a bit of force to put it back or there is another way
thanks
GAry
tashasdaddy
Re: lower unit refitting
line up the water tube. pull the spark plugs and rotate the flywheel, is the shift rod lined up it connector.
gazzatop
thanks , will try again tonight , all was lined up but had not removed plugs or turned fly wheel
tashasdaddy
did you grease the splines on the drive shaft?
