redbandit850
Thread starter- Joined
- Apr 15, 2009
- 6
So my friend and I thought it would be a good idea to replace the impeller in the outboard. It is two years old and has been run in salt water for a few hours so why not. I should have started here first as we can not figure it out. My friend got the seven bolts off the lower unti and it dropped down a little bit but will not come off. Now the lower unit will not go all the way back up into place either. I did read that our mistake was not disconnecting something in the upper unit. Shift rod, bellcrank? not sure what we have to do at this point. Your help would be apprecaited as at this point like I said the lower unit will not even go back into place. We still would like to remove it if possible!
