Lower unit removal evinrude 75hp 1976
flodan
Hi i have a real problem i have to change the impeller but the lower unit only comes 4-5 inch down for the shift rod stucks in the housing halfway tru i have looked at the shiftrod and it is bend at top are the rod a 2 peice unit or whats wrong <br />many thanks <br />Anders
flodan
Re: Lower unit removal evinrude 75hp 1976
Help i dont know how to do !! and i cant get a manual for the moment out of stock in my town have visit all marine shops today
rwcreigh1
check ebay for it. good luck.
breton26
did you remove the shift rod to lever screw??? it is located behind the bottom of the starter. try that and let me know if it helps
ledgefinder
Ensign
The shift rod is one piece (not two piece like the earlier motors). You have to disconnect it, as breton says, under the starter motor.
McGR
Are there a lot of deposits present on the motor? I had one last year that I really had to wrestle with to get out. It turned out that there was a lot of built up crud in the shift rod tube.
