Lower unit removal.
jerryjerry05
Need to know how to remove the lower unit on this motor. Thanks in advance.Jerry
Picture 001.jpgPicture 002.jpg96 Johnson.30 hp E30ELEDE G 04162578
Daviet
Re: Lower unit removal.
By your model number you have an evinrude not a johnson, no big deal, there both the same.
Look at the site below. Start by removing the water intake screens,#30, then remove the shift rod connector nut,#49. Becareful when you remove the shift rod keeper #73 that you don't loose it. Then remove all the gearcase screws #76 and the nut #54 and the gear case should drop down.
http://www.ishopmarine.com/ishop/js...CatFilter=BRP&eCatSupFldr=supplier-100-005-EJ
