Jack_toda_Max
Thread starter- Joined
- Mar 21, 2010
- 22
Hi,
I have a 1962 Evinrude Starflite IV 75HP. I inherited it from my great uncle.
I have cleaned it up and got it running but after water testing I have discovered the lower unit oil has changed colour slightly.
The drain/fill plug seals looked to be in perfect condition so I didn't bother replacing them. I didn't touch the propeller seal.
I do not have alot of knowledge with outboards. This is the first I have ever owned.
Are the drain/fill plugs and propeller seal the only places where seawater can get in?
I can't find a propeller seal in the iboats store. I found this kit, which contains a bunch of seals.
http://www.iboats.com/mall/partfind...gd_poid=110564&gd_row=53&**********=323616961
Can someone please identify them for me? Does this kit have a propeller seal? I can see waterpump gasket and seal.
This is the propeller seal.
It has 4 bolts on the outside that have O-rings on them. O-rings are easy to get and I will be able to replace these. I need help finding the oil seal in the middle. Is there anything else behind the oil seal that I should replace?
I don't want to get seawater in the lower unit and destroy it.
Thanks.
Thanks.
