jerry place
Thread starter- Joined
- Feb 3, 2009
- 13
i'v e got a 88 mercury 100hp that i recently bought. problem i'm having is i am getting water in my lower unit gear oil. it's not a lot but it's enough to turn the oil milky white in one trip. i've replaced the impeller, impeller housing seal, base gasket, the two rubber seals under the water pump base and the shift shaft seals. my question is where else can water be getting in? i'm thinking the prop shaft side? are the seals in there as easy to get to as the impeller side?
thanks, this forum has been a lot of help.
jerry
jerry
