Lower unit seals
alley mechanic
Hello all, its been a while since i have been on here my 98 115 intruder has been running well but i have a slight water intrusion in lower unit so i decided to reseal it when i do the water pump. I ordered the seal kit while waiting for it to arrive i found out that i had orderd the prop shaft seal some time back just forgot about it so i installed it it was the single double lip seal just like the factory had installed when the seal kit arrived i noticed it came with two single lip seals can i leave the single double lip seal i already installed? , also when taking out the prop bearing carrier i notised it had no rtv on the back flange and no gasket sealing compound around the oring area. I am the original owner of this motor and it has never been to the shop i do my own work , the shop manue says to use rtv on the back flange and gasket sealing compound around o ring.
Thans very much
alley mechanic
boobie
Re: Lower unit seals
If the double lip seal is okay, leave it in. ANY question, replace it. The manual is correct for sealants. Follow it.
alley mechanic
if the double lip seal is okay, leave it in. Any question, replace it. The manual is correct for sealants. Follow it.
i replaced it with a new single double lip sealthat i had i installed it per omc shop manuels directions, thanks boobie.
Alley mechanic
