bighermHK45
Thread starter- Joined
- Jun 17, 2012
- 92
Ok, I went to install the lower unit on the 1999 Mercury 125 hp and apparently the shift shaft was moved prior to install so it would not shift to all three positions (stuck in Forward gear).
So, I removed the lower unit and tried to find each gear position by rotating the shift shaft. I moved the controls to the neutral position. I put the shift shaft in the neutral position and reinstalled the lower unit.
I put control shifter in forward gear and the prop shaft rotated clockwise with ratcheting sounds and would not rotate (locked) to the counter clockwise position.
Shifted to neutral and prop shaft spun in both directions freely.
Shifted to reverse and the prop shaft would not rotate in either direction when rotated by hand. It was locked.
I read the manual and it does not specify if the prop shaft (when in reverse) should rotate counter clockwise. It just says that the prop should lock when attempting to turn clockwise.
I always thought the prop would spin counter clockwise and not rotate clockwise. The way it is now, it does not spin at all.
What is the correct function of the prop shaft as it relates to the shift shaft position (specifically in reverse)?
Should the prop shaft spin counter clockwise (and lock clockwise) when the gear case of lower unit is placed in reverse?
