Lower unit swap....1977 to a '74 70hp....controls backwards now
strap_76
I swapped the L/U on my 1974 70hp Evinrude. I took the '74 L/U off and put the '77 on. Now when I shift it is backwards. Forward is reverse and reverse is forward. Did install the L/U wrong? Is it safe to run it this way?
ezeke
Re: Lower unit swap....1977 to a '74 70hp....controls backwards now
You have to have the linkage from the other motor as well for it to work; everything from the shift lever to the shift rod must be swapped.
It will not last long at all running the way you have it.
strap_76
Thank you Sir,
After paying attention to the details.........I see the difference now, thanks. Next question is how do I convert? Can I just use the parts already on hand? Are their directions on how to do this?
strap_76
I appreciate the advice, direction, and your time. Thank you sir!
