redogman67
Thread starter- Joined
- Mar 30, 2009
- 5
Ok so I am attempting to put the lower unit from a 1970 Johnson 20 hp onto my current motor which is a 1974 Evinrude 25 hp. I have never done this and am seeking some guidance. I have pictures on my photo bucket because I can't post them here. They are of the 20 hp Johnson's lower unit. Here is the list of my questions
When I take the lower unit off here there is no gasket I have to replace right?
On the closeup pictures, do they look normal? and what is that black thing that is kind of curled up inside that tube? Is this the tube that water comes out of?
The pic with the drive shaft end: Is there nothing that secures this to the motor? Does it just slide up on my new motor without having to connect any thing other than the shift linkage?
I don't think I am going to replace the impeller right now because I want to ensure that this lower unit works before adding new parts to it. So if it looks ok than I will prob just attempt the swap and if I need to add a new impeller later I will do so. Any extra input is welcomed and appreciated. I am assuming I can just put this lower unit on my Evinrude in the reverse order in which I took it off correct?
Here is the link : http://s574.photobucket.com/albums/ss186/dkman67/
