Hydro Mark
Thread starter- Joined
- Mar 30, 2013
- 56
I just performed a pressure and vacuum test on my lower unit and I'm having trouble interpreting the results. Can someone help me out with this?
1968 Merc 1250 125hp Inline 6 - New drive shaft seals only.
Pressure Test: Held 15 psi overnight (actually went up as it got warmer). Held 6 psi for 2 hours with zero leakdown.
Vacuum Test: Put 15 hg and it leaked to 8 hg in two hours. The next hour down to 7.5 hg, which is where it is right now. Tried putting the oil in suspect places, but couldn't tell if it was getting sucked in or not.
My manual says do it at 15 and if it "holds" at 15 then do it at 6. If it "holds" at 6, then it's good. It does not give a time limit for holding, so that's where my confusion lies.
Thank you,
Mark
Thank you,
Mark
