Lower unit won't drop on a 1987 Johnson 50
jwcole04
I'm making my first attempt at changing the impeller. I've removed the brass shift connector and the 5 bolts holding the lower unit, but contrary to youtube videos I've watched, it still won't drop. Can anyone tell me what I'm missing?
Brass shift connector ??------There is only a threaded pin below the starter to remove.----Did you remove the trim tab?
saltchuckmatt
If you did the above, when was the last time it was removed?
Every hear of a stuck driveshaft?
Crosbyman
hopefully not the "first attempt" to replace the impeller in 37 years...
Drive shaft spines could be rusted in solid :-(
salt water engine or fresh water ?
