lower unit
bream master
HAPPY NEW YEAR 2 ALL,i hve a 35hp johnson model 35el77 and trying 2 disconnect lower unit,i hve followed my manual 2 no avail.It states to remove 4 bolts and 1 nut from the front as well as disconnecting shift lever.I noticed on my motor that when i tried 2 remove the 4 bolts 3 bolts came out with no probs,the last bolt isnt a bolt its some sort of a stud, sort of like a thumb tack,WHATS the go. :cool:
F_R
Re: lower unit
A flaw in the metal and the head snapped off at the flaw line??? Just guessing.
HighTrim
Re: lower unit
Some type of faulty bolt like Frank stated or a homemade thingymajig. Post a pic if you can so you can figure out to to replace it with a proper bolt.
bream master
Re: lower unit
thanks guys 4 the support,after stairing at it for 30min icouldnt work it out so i proned it off with ascrew driver and it came off thank god.Now that prob is solved.I hve a new impeller to put in but im having difficulty trying to get the impeller off im actually stairing at it thinking why wont it come up,do ihve to pull d shaft out or what.......... pls hlp.:redface:
tashasdaddy
Re: lower unit
metal base of impeller has siezed to drive shaft. some have tapped it and broken the bond, some have, cut rubber off and heated. some have taken dremel and cut the band, this guy scored the drive shaft.
Vic.S
Re: lower unit
The diagram HERE might help.
The impeller should slide off OK but watch out for the key.
There does not seem to be anything preventing the shaft being withdrawn either but take care not to damage the seals. Now is a good time to renew them anyway.
bream master
Re: lower unit
Thanks for the quick reply,OK i hve managed to get the bugger off ,now i cant seem to find the part number on iboats.I thought i wld just buy the whole kit if i cld find the part number.If it helps to anybody the part number on the housing is 323941............cheers:cool:
Vic.S
Re: lower unit
Go to HERE Find your engine by make year HP and model and click on "gearcase" and you'll get the diagram in my link and all the part numbers Impeller is 378891 but the availability is "limited"
the key is 317078. Click the magnifier next to the part number and it says the alternative part for the impeller is 775521
Pump repair kit is 388256 also with limited availability but the alternative is 389980
There is also a chrome pump kit if you want.
Only snag is the housing is listed as 322260 not the number you quote but a search of the BRP part numbers came up blank on that so presumably not a BRP part number
double check the numbers please before ordering!
bream master
Re: lower unit
Thanks so much for all d support the b.r.p website helped heaps.all of the numbers you listed proved were there.What would u do without this forum.you would be lost ...........cheers.:D
