lowrance 3500 depth finder
schwen
Does anyone have one like this , mine is busted :grumpy:
Re: lowrance 3500 depth finder
my lcd screen was a bit off and i did research on getting a replacement. you can find some on ebay once in a while, but from my research, they all go bad so i decided to not replace it. this is a lowrance issue, not doral.
i ended up replacing the whole thing (gauge and transducer) with a different system since no other gauges will work with that transducer. i used a raymarine B60 transducer to the E7d chartplotter and a Lowrance LMF-200 NMEA 2000 depth gauge. now my depth gauge and my Fusion Electronic remotes can view all my NMEA stuff including the depth.
+1 and will add
The one on my rinker went bad also and have not yet replaced. Only one they make is now the 3800 and the ender plug in does not appear to be compatible with the transducer. Don't like the looks of the 3800 so I'll be going another route my self.
