Lowrance GlobalNav 11a (2a ?) GPS
Dewi
I have one of these without any cables at all - does anyone out there have the ones I need they can sell me - or anyone give me the part numbers for the original leads or equivalents - I have a Garmin Antenna (co-axle cable) can I use this if I get the correct plug - can anyone tell me the pin configuration of both sockets - small one 4 pin - larger one has a 7 pin possibility (including the center pin) but only 4 of these are used 3 in a row - miss one - then another one
it seems a shame to let it go to waste :) :) :)
Thalasso
Re: Lowrance GlobalNav 11a (2a ?) GPS
Call Lowrance tech dept. They will help you out. Just have time to set on hold. they are pretty helpful. After you find out what you need you can search online and E-bay. They will give you part #'s. I really doubt anything Garmin is going to fit on a Lowerance, unless it is NEMA2000 cables.
