new to me gregor seahawk g-4 with lowrance x-102.
does not have speedometer.
have extra transducer - speedometer cables.do not know what they are from.
transducer has 2 cables with gray connectors. large diameter one #m-0025, and small diameter one #m-0475.
speedometer cable # m-0475 - also gray connectors.
the x-102 has blue hook up connectors on the unit head.
can the new transducer - speedo cables be used with the x-102 unit?
they fit , but can i hook them up without damaging the unit so i will have speed reading on graph ?
also the new cables are quite a bit longer than the cables now in use. will it be ok to just coil up the excess cable ?
Thanks in advance...captn-tin
