lowrance X50 DS PROBLEM
jack450
HI, Ihave a lowrance X50 DS it is 1yr old and did not give me any trouble. Yesterday while installing a hourmeter I was checking fuses, I inadvertantly unhooked the fish finder, and of course had to restart it. But it will not turn on now I checked fuse at block, unplugged cable and checked pin at end all are ok with juice, but head will not go on. Anybody have an idea of problem? Jack
rndn
Re: lowrance X50 DS PROBLEM
Did you make sure the negative wire was also hooked to the battery's negative post?
jack450
It is hooked up at the ground on fuse block, but I did not check for good contact ,will try Thanks
