lt10 and 3802a
lt10owner
i was wondering if there is a rebuild kit for the carb on my lt 10 very hard to start and also some of the head bolts are stripped so i know that could be the problem since its not sealing properly but it is 60 yrs old it doesnt look like a carb though strange looking to say the laest but i love it
aganser
Re: lt10 and 3802a
I see Vintage Outboard has a carb kit for a Johnson TD/TN motors. The carbs on those are similar to your LT and should help. You may also have to thoroughly clean your float and reseal it with either cyanacrylate (Super Glue) or a fuel proof dope used on model airplanes. Or you can by a Mercury float and retrofit it. Easy fix.
The carbs are kind of weird but not hard to work on. My son rebuilt a Johnson TD carb at the age of 12. The carb actually contains the primer and high speed circuits. Low speed is a rotary valve mixer deal directly behind the gas tank.
You can get more help from the experts here as well:
http://www.aomci.org/cgi-bin/yabb2/YaBB.pl?board=askamember
Leather primer seals are also available from a AOMCI member.
Good luck and have fun! :)
Bob
lt10owner
Re: lt10 and 3802a
the water pump is fine i think it is pumping quite well so i have a 68 3 horse light twin model 3802a how hard is the impeller to replace? i looked at some schematics doesnt look too bad i have worked on many engines from weedeaters to 18 wheelers i think im capable but ya never know
aganser
Re: lt10 and 3802a
You may want to change the pump rotor on the light twin. I did a Johnson JW (same motor) and they're easy. Parts available through BRP or Sierra Marine (NAPA). You can borrow a manual from the library to help you out.
Bob
lt10owner
Re: lt10 and 3802a
thank you aganser i appreciate your expertise do you kno of anyone who might have a carb for my lt 10 or any old motors they dont want as id be interested in them i am wanting to start collecting old evinrudes johnsons and maybe mercury
lt10owner
Re: lt10 and 3802a
is there any swapmeets i live in southern indiana where are good places to go flea markets??
