stratodown
- Joined
- Jan 15, 2008
- 22
I'm about to refill my lower unit with lube, and was wondering why the manual says to fill from the lower hole? There's a perfectly good upper level hole that seems a better/cleaner place.
I find these pumps much easier to use than the tubes, not to mention cleaner. Dont forget to change the gaskets as well while you are at it.
I used one of these until I lent it out to a friend !!!!! I have not seen it since !!! so last fall I went with the old method of squeezing it in.
Fill from the bottom = No air locks.
Im not sure if you have a Princess Auto around you, but they carry them at a pretty low price tag, about 4 bucks.
