Lube Leak in '82 4.5 hp Johnson
JG4909
I have lube leaking from the port "weephole" at the joint of the gearcase and leg.
Any ideas on cause/solution?
Vic.S
Re: Lube Leak in '82 4.5 hp Johnson
You would expect to see some unburnt oil from the fuel draining from there.
Provided it is not gear oil you have no problem. if you think it is check your gearcase of signs of water ingress ... milky oil
Read http://forums.iboats.com/showthread.php?t=207285
JG4909
Thank you for the help. This reply is long overdue. Had some computer issues. Again, thank you.
