Lube Oil in cooling water?? HELP
donlee
I understand water in lower unit, but the other way around? Can anyone help! Also, anyone know how to get to thermostat in 1971 7.5 HP Merc. Not shown in service manual that I have. :confused:
Yepblaze
Re: Lube Oil in cooling water?? HELP
"Lube oil in cooling water"<br /><br />How did you determine that?<br /><br />Do you have the parts breakdown? Maybe that would give you an idea where the thermostat (if it has one) is located.<br /><br />I think they have parts breakdows available online at http://www.mercurypartsexpress.com
donlee
It may be a wrong assumption, but appears to heavy oil/grease draining draining from lower unit water drain, and at exhaust relief outlet. Too much for exhaust oil, or so it appears. Also, running in tank, water becomes greasey very fast, and I am losing lower unit lube.<br /><br />I will try to find a parts callout. Thanks
roscoe
If you are losing oil from your lower unit, then water will be replacing it in the lower unit. Time to replace the seals in the lower unit.
