lubing shift cable core wire?
natemoore
Master Chief Petty Officer
Should I oil or grease the core wire before I re-insert it into the shift cable outer casing? Manual is silent on it, but it seems like a good idea to me.
Nevermind. Found the answer: do not lube (according to sterndrives website).
EddiePetty
Re: lubing shift cable core wire?
...the newer OEM lower shift cables have a super-slick poly liner that requires NO lubrication. Matter of fact, if you add a lubricant you may just be inviting contamination.
FWIW...Ed in 'ol Virginny
