Lucky guy gets a 1966 Evinrude 80 free!
chestypuller
got lots of spark! woo hoo.. now i need to figure out how to set the timing of the distributer to crank now that i reinstalled the distributer.
did a compression test and its only about 80 psi per cylinder. dry.
chestypuller
i wanted to mention that these plug wires screw into the dist cap, the ebay seller thought they pulled out and tore one out.. no biggie i can recrimp it onto the bolt type end, but just wanted to let others know so they dont do the same thing.
chestypuller
got it to fire up, wouldnt run much have carb off now to clean it out, its really dirty!
Your compression is pretty typical, as they are all 80 - 90 PSI. As long as all cylinders are within 15% of each other, the compression is fine.
