Lugging my Javelin?
Marc J.
I'm looking to purchase a new prop for my fiberglass 16'8" 1990 Javelin F&S. The boat was left uncovered for some time before I purchased it and I believe it gained some weight. It's powered by a 89' 90hp Johnson. At WOT with just me it runs 41 mph at 5250rpms. I once saw 5400rpms with much trim. With a couple more people aboard it will only run 37-38 at a little under 5K. It currently has a 13 3/8 x 17 painted steel OMC prop. I raised the motor up as far as it would go earlier this year. It also has a stingray hydrofoil. Should I go with a 13 or 15 pitch to get my rpms up?
Marc J.
Re: Lugging my Javelin?
Without the hydrofoil, the boat is slow to plane. I don't think the WOT rpms are affected by it since I raised the motor. Only the outer tips are splashed by the wake once on plane. I'm strongly considering the two Michigan 15 pitch SS props on sale.
walleyehed
It should swing a 17 at a much higher RPM...do we know the engine is good and healthy???
Marc J.
Compression is 120-130 on all four per my tester. I cleaned & sync'd the carbs and set the timing earlier this year. Boat feels really heavy in and out of the water, nearly twice as heavy as my antique. If it can swing a 15 at 5600-5800 would it prove anything?
