Luhrs 35 tournament wall removal
migber
I'm in the process of repowering my boat. is there a way to take out the wall to make it easy to remove my detroit 8 cil and put a pair of cat 3126. or do you think that I can do it through the door?
zool
Those DD 8.2 N or T are 32" wide, the Cat 6cyl is less wide. You probably need to measure the door opening, I would explore tearing down some of the detroits for removal if the doorway is less than 32", which I doubt it is. The Cats will fit in without a doubt at 26-31"
