Re: Lund 1700 Fisherman Series - 115HP Yamaha
If you are going for bow lift, you won't get it with a hydrofoil. A hydrofoil will raise the stern, making your condition worse. Have you really experimented with the trim of the motor? How is your weight distribution? Do you have heavy items forward like fuel cell, batteries, that sort of thing? A prop change can fix it, one of the prop guys here could probably talk about a prop that can help, but I would look at your setup first. It is possible that the boat is fine but you have an expectation that isn't correct. If the boat is running on the last 1/3rd of the hull at WOT and you are turning the proper RPMs for your motor then you are probably okay. Good luck...
