Re: Dealer drilled a hole in my fuel tank
the hole is about 1/8 inch.
okay my rant; sorry but I need to vent.
It gets worse. They drilled holes in my gunnels that are incorrect as well. The ski bars aren't angled correctly. The bottom plate is off center by 1 inch as well.
Plus, they installed the satellite radio antenna where my riggers, rods etc hang/ go ( not in a logical spot near the factory antenna) and the plugins for the electric riggers where my legs hit when you are sitting. I'll most likely step on them and bust them off .
They never listened to anything I requested. I'm disgusted with this Lund dealership. How are they even in business I do not know.
Here is the best part.
I have a 24 volt troller on it right...
2 batteries for that, one for the main motor and I asked them to install a forth battery for my riggers with 10 gauge wire for the riggers please and to be sure it will work with my 3 bank charger and not drain my main. Sounds simple eh...
I come back a day later to see how things are going and they tell me I don't need a forth battery, and that my 3 bank charger is actually an inverter.
That hooking the 12 volt riggers to the trolling batteries ( on one each side) is just fine. I said what? The motor is 24 volts, batteries are in series and I have a 3 bank charger, not an inverter. The riggers are 12 volts!
They said . No, that's nonsense. We've never heard of a 24 volt trolling motor and you have an inverter. I said did you see the fricken 110 volt plugin man. Its right here! (They also used 12 gauge wire but told me they used 6 gauge).
They still refused to believe me that the trolling motor was 24 volts after the entire week has passed. I'm busy working so I can't keep baby sitting this dealership. You'd think that a large dealership ( maybe 30 employees) and the only Lund dealers within hours would know how to do things right. Read manuals, Call Lund or mercury etc for advise if you don't know for sure, yes?
Lund. These guys should loose their dealership.
Finally after a week ( boat PDI still not ready AHHH!) they realize, I'm right... that its not wired right for the riggers, that I need a forth battery independent to the trolling batteries.
During the time I spent trying to watch over the wiring for the riggers I looked around the boat and found the hole in the gas tank so we are here now.
I'm going absolutely nuts, I'm so stressed over everything that has happened in the last month with this dealership. All these years of waiting to have a nice boat like this and I'm getting this card dropped on me. I must have pissed some sailer off in some past life lol..
So here I am guys... I'm afraid they will screw something else up when I force them to replace the gas tank now.
I just want to get it out of there as fast as I can, never to return.
HELP!
