Do it then erik. Where is this going to be posted?
eric do you have a shareaproject page or photobucket or something?
I'm new to this site and took a look at your project "AWESOME". I owned a 1984 Nisswa 16 footer with a 50hp merc.tiller. I bought it from my brother who purchased it new. The floor was replaced, I believe in 1990 by Lund and I replaced everything topside in 1998.The floor was still solid but the livewell was getting a little punky. Should have went all the way but didn't. In 2006 I purchased a 1991 Lund pro V 17 footer with side console. I refurbished it in 2007 and went all the way down to the studs this time. Turned it into a Tiller model. The nisswa was a unreal boat way ahead of it's time. I had a chance to fish with Walleye pro Mark Martin in 2007 and we talked about the Nisswa and he said he loved it and would like to buy another just as a keep sake. I would really like to see your project done. Looks Great.Stringer final fitting;
Cut out notches for cross member supports, and cut out where the livewell drops in, also put a roundover on all edges to ease the turns for the fiberglass. Holes are predrilled for the removable center floor section support brackets, oversized holes to waterproof them with epoxy.
I have decided to glass over the tops while still out of the boat, then bed in the outboard stringers first, glass them in, then bed in the Inboards and glass them in.
Oh By the way, my PL Premium applied 3 days ago is still wet in the center of the Transom bedding, it is not runny wet like oops experienced, but none the less wet, I found this out because I wanted to trim some excess areas off, as soon as I cut into it I could feel it was wet, temp was not a factor. What concerns me about this is should I use it to bed stringers, I have some areas over 1/4" to bridge.
Lund
Thanks JC for the encouragement! I am dreading the foam days, when they come.
Nisswa,
Thanks for the Input on the Nisswa, Not that many people have seen them since only made a couple years. I agree and have said for years just what you said, "The Nisswa is a boat way ahead of it's time".
That is why I have kept it for all of these 22 years, and I plan on keeping it for another 22 years and pass it on to my son, so I hope I can do a quality rebuild, then keep a close eye on it in the future to stop the rotting before it starts.
I believe that putting a cover on it when wet is what caused the majority of the rot to start, never had a chance to dry out, remember taking the cover off many years ago and actually had some mushrooms growing in there. This time around she will stay in the garage, cover off, hatches open, bow high.
Todays update is short
Glassed over the Tops of the Outboard stringers.
This Boat building is very time consuming, just this small job took over 4 hours, prep stringers, prep glassing supplies, cut strips to fit and have stacked in order, do the lay up-then clean up.
Enjoying every minute of it, these guys have said over and over on this site, and they are right, boat building is a self rewarding project.
HOW DO I GET A FIBERGLASS SLIVER OUT OF FINGER<HURTS LIKE HECK>???
Lund
Thank You but I owe alot to my buddy who is a fantastic body man painter for years. He is super talented and he spent around 55 hrs on the hull. he had the whole boat suspended in his shop and it was a real sight.Here is a few more pics.Nisswa, I believe the 18 footer you are speaking of is the Cherokee.
Happens to be I have found a cherokee with Transom troubles for next to nothing, no motor or trailer though, that just may be another project if I can find a trailer.
Your boat looks like New!
Lund
