Re: lync and synce confusion , please help
cheers schematic
youve helped me a lot on this, and so have many others.
but i did get a fair bit confused with the taking the wires off the solenoid to day.
when i took the red and yellow wires off the solenoid i got NO spark.!!!!!
when i took off just the yellow i got NO spark !!!!!!!!!!
both of these were with ignition key in the on position !!!!!!!!!!!
so out came the plugs to check to make sure whats happening, definitely no spark at all with both the
yellow with red stripe off and plain yellow off.
also tried it with just one of the wires off and done it with just yellow off and just yellow/red off NO SPARK.
Put both wires back on and SPARK straight away ?????????????
anyway took the white with black stripe apart and grounded the wire to powerpack.
managed to get a timing mark up and set it to about 5 degree's.
then put fuel line on and managed to start the bugger.
the revs were about 850 to 900 and a bit rough to be honest so thats probably carbs need setting up better.
put the engine into gear with a big prop so its well under load and got 4 degree's ATDC bang on the mark at about 650 to 700 revs.
now i have a little vid of the engine running below, its not right but its a lot better than not running at all.
again this engine will run great over 2000 rpms and seems smooth at that rpm onwards.....
at idle i have the lever on idle stop screw and the cam plate pointer fractional off the roller but in line with mark.
now the idle warm up lever will only take this to about 1300 to 1500 rpms !!!!!
and as soon as the throttle main lever starts to move so does the butterflys, the advanc e DOES NOT move unteill the butterflys
are opening for sure,its about 1200rpm onwards that the advance starts to move !!!!!!!!!
definitely not before the roller moves.
ive also put a vid of that to show how it is set up, im sure everyone elses must be the same.
video of it running in water butt on idle in nuetral.
Evilrude is running again 1 - YouTube
video of the cam moving the roller before the advance moves !!!!
cam on roller before advance moves 1 - YouTube
video of the control levers and advance moving etc
idle timing 2 - YouTube
so now a new fuel pump is about to be ordered as i know this one is bad.
im not going with the VRO type i want an old style reliable pump that i can always get a rebuild kit for cheaply.
i know they are all old style etc,but never had problems with them in past so will be going that way.
now i hope i have the lynce and synce right, if not im definitely going to start drinking heavily and smoke a
load of the jamaican sweet smelling herbal cigarettes and leave it to someone else.
i have got so confused with this :facepalm: , and yet it should of been a simple thing to do !!!!
thanks to everyone for putting up with me on this topic,
its been like watching paint dry for some of you i know, but atleast it actually now runs.
(not great, buts getting there)
phill.........
