Re: lync &sync
Take a close look at how the throttle linkage works. I *think* on your engine the spark advance gets stopped at about 1/3-3/4 throttle. That is to say, the armature plate stops turning. After that, I think it just continues to open the carburator's throttle plate.<br />So, if I'm right, link and sync doesn't really effect wide open throttle performance.<br />Make sure, though, that the armature plate is moving freely and that it reaches it's (non-adjustable) stop properly.<br />I had an engine once that had exactly the same symptoms - but the clicking was pretty faint. It turned out that the cracked ignition coils were arcing over at a particuliar RPM, so the engine would hit a plateu where it would misfire and not go any faster. They made beautiful sparks at pull start speeds though. A clicking could be heard which was the coil arcing over.<br />Make sure your pull start isn't hitting the flywheel too. That makes some pretty loud clicking!<br /><br />PS - I had a look at my history. Somehow I end up replying to your questions a lot! What are the chances?
