M-167 1999 Suzuki 50HP 4 stroke
RickyRegs
The fuel injectors and fuel rail need serviced due to bad fuel.
I am looking at this motor and is described as runs great, go compression. The fuel injectors and fuel rail need serviced due to bad fuel.
I haven't had any hand-on experience with a 4-stroke or any fuel injected system.
How serious a repair is this?
Ldavidgrover
Re: M-167 1999 Suzuki 50HP 4 stroke
It can add up quick. If it had water damage the vst that has you high pressure fuel pump could be rusted. I would pull that and inspect. Change you high pressure filter ( black filter) and inspect fuel rail for corrision. You can sent the injector out for service which is cheaper than a couple hundred dollars a peice for new ones. Good Luck
