LukeFishWalker
- Joined
- Jul 23, 2015
- 95
I am getting an unusual amount of water coming from the hole in the mid section shown
in the picture and low water pressure from the tattle tail. I had ran through some shallow water and I assumed that I had picked up something so I got towed back to the launch. When I got home I pulled the lower unit and inspected the pump, the impeller was fine but I had a spare and used it. The metal cup & plate was fine so I left it. I then pulled the thermostat and found signs of vegetation and very small corrosion. So I had a damaged washing machine hose and stuck it on the pipe and ran water through it. Is it possible that I disconnected the pipe from the engine base leading into the block? and if so, can I tap it back into place or do I need to pull the powerhead?
Thank You For Your Time & Patience,
Lukus
in the picture and low water pressure from the tattle tail. I had ran through some shallow water and I assumed that I had picked up something so I got towed back to the launch. When I got home I pulled the lower unit and inspected the pump, the impeller was fine but I had a spare and used it. The metal cup & plate was fine so I left it. I then pulled the thermostat and found signs of vegetation and very small corrosion. So I had a damaged washing machine hose and stuck it on the pipe and ran water through it. Is it possible that I disconnected the pipe from the engine base leading into the block? and if so, can I tap it back into place or do I need to pull the powerhead? Thank You For Your Time & Patience,
Lukus
