m50d tohatsu
toonin22
Took the boat out two days ago and everything ran perfectly. I took it out again today and starts and idles fine, when I go to wot it doesn't jump up like it usually does it hesitates for a minute and if I keep throttle there it will get up to full rpm and stay there no issues. Did compression fuel sample and checked all the fuel lines am at a loss. If you have any ideas please help.
Sea Rider
How old is that engine ? Probably you already have s spun prop, make a wot prop slip test.
Happy Boating
toonin22
It's a 2002 or older is the only way I can see to find a year.
toonin22
Put it in gear and pushed on the prop and its not spun. Really don't know what else to check. Please any other test or suggestions.
Sea Rider
You have a 13 yeal oldie prop, props must be tested at wot trail on water, can't tell with hand....
Happy Boating
