Wee Hooker
Thread starter- Joined
- Sep 11, 2005
- 618
Ok, stuck the new Wp impeller in so I could use the boat this week while on vacation. ( The old one had two of six vanes left! I'll order a complete kit and do it right in a few weeks before my ME trip. ) Everything was going GREAT and quickly until I went to reinstall the lower leg. Put the shift in Reverse as manual states, slide in drive shaft and align shift rod linkage in the clamp but the shaft is stopping about .25" short of getting the water tube into the Wp housing. ( about a 1.5" gap between upper and lower leg mating surfaces. I've tried turning the fly wheel and prop shaft to align splines but nothing seems to work. Splines look good. Upper shift lever and lower gearcase shift rod are both in reverse. What am I doing wrong? Should I tap the skeg (gently) with a rubber mallet? ( Really don't want to do this!) This was supposed to be the easy part but I'm about ready (after 2-3 hrs) to drop off the mess at the dealer!
Any help DEEPLY appreciated.
