i would use fuel.... for spraying. water id keep away from electronics...
would crankshaft seals or bad reeds make a lean condition?
are you mixing 50:1 tcw-3 gas oil mix is it pre-mixed?
I don't have a bad idle I mix feul 50:1 in new gas tank with new fuel hoses all the way to carb. I have clean carbs seven times including pulling all plugs and replacing unless just a bad carb they are clean. I have good timing at ide and at wot carbs open and shut at same time. this is what is thowing off every one the one machanic I took to, replaced head gasket and cleaned carbs why he changed head gasket don't know didn't change anything not going to waste money on him guessing I can guess and not waste money no one else close to me, I hope to get another set of carbs next week to try on boat see if that works, but will try card method to see if any gas coming back out of carbs thanks have checked under fly wheel it's dry not for sure about bottom seal. Thanks for all infoExactly!!! Air leaks are the answer! While compression is important for compressing fuel before spark, the action of the piston also "works" (opens and closes) the reed plates. Any air leak from bad gaskets, broken or poorly seated reeds, or bad upper or lower crank seals may decrease that vacuum in the crankcase and therefore it's a good bet why you have a bad idle condition.
How to check that:
At full throttle take a business card and hold it about 1/2 - 3/4" in front of the carbs. The card should vibrate/oscillate. If it saturates with fuel, your reeds are bad.
If the idle clears up with motor oil sprayed around carb and reed plate gaskets you have an air leak.
If you pop off the flywheel and it's saturated with oil underneath, your crankshaft seal is bad.
All this is of course what you should be looking for as well as ASSURING your carbs have been cleaned, floats set, timing synchronized, etc. There is also the possibility your ignition system or coils are going south so check for voltage/ohm readings on those as well.
I have seen some 3 cylinders over the years that just dont like the factory suggested set-up and like a little more timing before fuel, try opening the roller to a 1/8 gap and retest.
Pulpwood... read the post again. If your carbs are clean, gas is good and all else you say is tip top shape you would not have an issue. There is more to it that that. Mechanics are stumped because they are not listening or willing to hear what others are saying. So if all else is good.........................
Check reeds and check the ignition. Something is at fault here.
........Timing is set at 5 deg at idle and 20 deg full throttle.......
Even put new ngk spark plugs in today no difference reset linc and sinc no change what ever I do same problem. I have some more carbs to try coming tomorrow.
I have tried bringing it down to tdc but it will shut down. 5 deg is what other outboard are generally set and it would idle smooth when set there. I went today to the river and tried several different things I even advanced the timing to 8 deg then to 12 deg but as soon as I put it in gear and give throttle it would shut off. Even put new ngk spark plugs in today no difference reset linc and sinc no change what ever I do same problem. I have some more carbs to try coming tomorrow.
The spark plugs I had before were new champions told to change to ngk gave them a try no different Yes carbs are for 1984 70 mine is a 1985 70 motor told should not make a difference, work with last owner. As for timing machanic said he generally has to set timing on those motors to around 8 deg. All I know is will not run at tdc. Working on it again this afternoon when I get off work, got a guy who races boats to help tell you what we find. Sorry no pics were posted first time using forum wasn't for sure how to post them. Again thanks for all the info
