1990 2.0 seadrives. no spark took flywheel off to clean corrosion from stator noticed sealant was coming loose from magnets. magnets that had sealant loose moved. so I put them back. No problem or so I thought put it back together. Got spark. But it seamed the flywheel was nnnot seated all the way. Nut flush with crankshaft. Other engine has a least a thread protruding. hmmmm so disassemlied again this time magnets got stuck to stator. Can these magnets be successfully glued back in. I'M worried about tearing the crank keyway up if something gernades up there.
