Magnumdeke's 1969 Starcraft Islander Restoration
fat fanny
Re: Magnumdeke's 1969 Starcraft Islander Restoration
J think of it as motivation! nuttin but love for ya thou.
jasoutside
I'll take it! Fist bump:cool::D
Hey mag, so scrappin, we need some more words about this. Let's see the damage man, what do we got?
magnumdeke
Ya tonight I will get interior pics, gonna take a night or so to build a cart to move it around and flip for bottom shots. I knew the damage was there just got some cold feet thinking about the money I am going to stick into this with the potential for hull failure or leaking. I can fix anything, we are just going to have to think it through!!!
magnumdeke
These 4 rib reinforcements are cracked
Two ribs have cracks in hull under them
Plus the chine on either side
magnumdeke
couple more pics,
underneath
NOT GOOD :mad::facepalm:
More pics to come after flip of hull
jasoutside
Shooooooooooooot:(
Yah, I'm seeing failures, repairs and failed repairs. Rats.
magnumdeke
Ya don't look good does it, I just wonder if it can be stopped or not??? Drill the ends of the cracks and weld??? Risky way to spend 7 to 10 grand fixin up a boat I have to worry about cracking apart............
jasoutside
OK, so wait, question...
Are you a welder? One with lots of excellent alum welding experience?
magnumdeke
Ya I got experience, just dont understand the forces on the hull that I am going to be fighting!!
jasoutside
OK, well, here's what I was thinking....
I'm not a welder, so, I don't know very much. But what I do know is that welding alum is a tricky biz. To get it right and strong is a challenge. Also, re welding really messes with the strength of the original alum material.
Anyway, if you would have to pay somebody to do it, forget it. The expense would be silly and no telling the welders experience/quality even if you did pay the price.
Now if you have the skills, maybe take a run at it. But, if it were me, I'd also run some mechanical means to make the repairs. In other words, alum patches, plenty of 5200 and closed end rivets, right over top of the welds too. Easy? No way. Those angles and ribs and stuff will make for some complex and tedious fabrication work.
IF you could get a solid weld AND a backup patch over the cracks/damage, I'd feel pretty good about moving forward.:)
If not........
well....
:(:facepalm:
fat fanny
It almost look's like it was crushed from the sides. Your already prepped for weld except reoming the ribs above the cracks drill hole at crack ends and bevel tig a couple overlapping beads and maybe a patch plate seam the outside after grinding out old welds leak test and give her a try witht he O/D hole patched over and a small tiller attached on the water to see if she holds. But I'm sure you have been runnin scenerios in your head already! Keep updating. Good luck!!!!
magnumdeke
I think most of the repairs could be done from the outside with some welds on the interior for the rib and rib rivets repair, drill ends of cracks, weld cracks, weld heads of rivets in place, weld patches over rivets and the welded cracks and maybe then 5200 patches over everything with new rivets out side of the whole original foot print, all exterior work. Now for the cracked chine all I got is to drill out the end of the cracks and weld inside and outside and grind,sand,polish the exterior, still wonder if that chine will recrack! Gotta flip it and check it out. Hate to scrap it, but....????>>> Scary!!!!! to say the least. I have confidence in my skills but not in tired Iron so to speak!!
magnumdeke
Well here goes the flip
Got it off the trailer by myself and then enlisted two coworkers to help flip it by hand, Piece of cake!!!
Made a rolling platform out of two 4x4's. 1 sheet of O.S.B, and three dunnage boards, and 4 8" casters. Rolls like a dream.
Next post will be the rest of the bad stuff
magnumdeke
Oh ya before the flip I braced the hull
magnumdeke
And now two posts of the bad!!!!:(
magnumdeke
Straight edge shows the dent
and the other side
Calling on another hull tomorrow, if that goes well then this is done if not, I will try some straightening and welding!
jasoutside
I have hope for this boat:redface:
If you are comfortable with your abilities to weld and are game to fab up patches n stuff, I do believe she can float again.:)
magnumdeke
YA i WANT TO MAKE IT A GO!!!!!!!!!!!!! whew had to yell that much better now, I think drill the rivets out, strap hull to cart, porta power off cart and straighten, then weld cracks and rivet holes closed, then make oval patches and weld in, then drill rivet holes, add another 5200 patch and rivet together to ribs and hull???????????? opinions please????????!!!!!!!!!!!!!!!!!!!!
