lindy46
- Joined
- Nov 27, 2008
- 3,886
Re: Maiden Voyage on new Glastron Skiflight w/ Evinrude 40
The hypoid gear oil will emulsify water that gets in to a certain extent, and will continue to lubricate. Try running the motor a for a while and then drain the L/U. If milky oil comes out, the hypoid is doing its' job. If water runs out first, before the oil drains, then there is too much water intrusion and the leak needs to be found and repaired.
Hello,
I just disassembled my water pump housing, and took out and replaced my impeller. I found standing water in/around the impeller. I could also smell the foul odor of gearcase oil, so I removed the plate that the impeller sits on, and remved the driveshaft. Then I dumped the water/oil mixture remaining in the l/u. My question; Is the main concern with water in the gearcase with corrosion? I mean, should I worry about other possible damage if water is in my gearcase instead of oil? I am asking because I plan on re-filling my gearcase with oil and taking it out this weekend, even though I know it still leaks. My assumption is that the oil will get mixed with some water, but there will still be enough to lubricate gears ect.
thanks for all the great replies.
