Maiden Voyage
waterbabies81
Well she floats... and doesn't leak...
The motor goes like this...
lift for cold start bar, check
neutral check
flick a switch under the key and I'm assuming its an electric choke.
she fires right up... high idles till you drop the lever.
forward and reverse have a small amount of power but as you increse the throttle the power stays the same.
not backfiring
Im thinking its fuel related
1976 Johnson 135 seahorse V4
xjdriver
Re: Maiden Voyage
Have you checked to make sure your carbs are opening when you give it throttle?
waterbabies81
Re: Maiden Voyage
wouldnt even know where to start lol.
shes got the 4 slow speed mixture controls and thats all I know
boobie
Re: Maiden Voyage
I think a service manual would be a good investment.
boobie
Re: Maiden Voyage
Sure, I'll post the # the 12 th of never.
waterbabies81
Re: Maiden Voyage
lol, it would seem we have some good write ups on here.
I'll be rewiring the boat this weekend and the motor is coming off for a tune up.
Daviet
Re: Maiden Voyage
Have you watched the linkage on the engine, is it moving when you move the throttle handle, maybe cable is broken or not connected.
