Main fuse
2001 monark 200
I have a 2001 monark 200 pontoon. I’m looking for main fuse. I have no power to the fuse panel. Nothing near the battery.
captmello
you're going to have to keep looking. I can't see your boat, but my fuse panel is in my helm. so, can you get inside the helm? start working your way back? do you have a "master" switch at the helm?
first. clean every battery terminal and connection starter in the battery posts and work your way up the wires to the dash.
use a volt meter and a test light to troubleshoot where the power stops.
going to assume this is an outboard. there is not a "main fuse" per se. there is sometimes a main circuit breaker. sometimes there is a battery switch.
as we can not see your boat. we do not know what you are working on. we also do not know what the prior owners did for the past 22 years
