krazykatz911
Thread starter- Joined
- Aug 21, 2010
- 123
Hello, I wanted to thank you in advance if you can help answer some questions I have:
I have a 2005 Stingray with the 4.3 GL-D and the SX-M 1.79 Outdrive.
Thank you so much!
- I replaced the fuel filter yesterday, Do I need to pre-fill it with gas before trying to start or is installing it empty ok?
- I replaced the impeller also. The original was 2 seasons old and looked great BTW. The bracket that comes off the block, has some kind of tar that cushions in between the water pipes, how can I replace that? (Was messy)
- What fluid do I use for the Trim? Do I replace the Trim fluid ever year?
- What fluid do I use for the Power Steering? (Didn't know if there is a special kind)
- The outdrive gear oil, I found the Volvo fluid, but wanted to know if anyone can recommend a good synthetic aftermarket fluid? Do I change this every season?
- Does this engine have a PCV valve, I couldn't find a replacement number in the volvo parts section?
- I just replaced the plugs, wires, cap and rotor. (126 hours on boat) Anything else need to be done?
- I changed the oil last season in April, 2012, and we only had the boat out once last season. The boat stays in our garage. I checked the dipstick yesterday and the oil is as clean as the day I installed it. Should I change the oil anyway?
Thank you so much!
