Major backfire at start-up
HighTrim
Re: Major backfire at start-up
Backfiring out of the exhaust port is caused by having the ignition system fire a particular cylinder when the exhaust port is open ( ie piston down). This would sound like a shotgun going off..... is this the condition that you're experiencing?
This is usually due to a sheared flywheel key, a flywheel with melted (moved) center sensor magnets if they exist, timer base leads routed incorrectly to the powerpack, or having the leads from the powerpack to the coils reversed to mention a few.
yodel3
Yes. I would say that it is that loud. What would you check first, and why does it seem to only happen during starting?
thanks
clemsonfor
my 1971 25 will backfire/sneeze and stall while cold but after say 10 seconds wont do it, but it does not sound like a shoht gun! Does not sound bad i guess its more of a sneeze?
-nate
F_R
You are saying that it runs fine once it starts? Idles good and has full power? Then it can't be much other than improper throttle position when starting. Proper throttle position is in neutral gear, throttle advanced as far as it will go (in neutral). It will only go as far as the shifter interlock bar allows. Does that stuff look OK?
clemsonfor
Sorry FR i think i kind of hijacked the thread i think you were responding to me? My sneeze is probly due to the throttle being to advanced, yes mine runs fine after a few sexonds im not sure about his sorry i was just adding my symptoms in case his were the same and he was mis discribing them.
-nate
munch
i have the same problem. except mine won't start
yodel3
I haven't had it on the water, so I can't verify that it runs well under load. Only that the loud backfiring seems to stop once the motor is running.
