Major play in wheel , around 3 inches.
ilove2fixx
Play in steering wheel Bayliner 205 ..
Hi guys next issue , lol theres some play in the steering wheel .. about 1/2-1 inch of play .. and steering a little hard
The play is normal for cable steer, but if you have power steering it should be easy. Do you have power steering?
and as always what motor?
ilove2fixx
Yes I do have power steering it's a bayliner 205 5.0 engine
Like when I move the wheel left and right there's like.an inch of play .. that's normal ?
For the most part yes. The helm is a gear and the cable is a very long spiral gear. So 1/8 of an inch of play with the gears will give you an inch or more at the wheel. There is also usually another 1/8 inch of play at the steering ram. When your running on plane you should not notice much of the play, but do notice it more at slow speeds.
Do you have more then what I've explained?
ilove2fixx
No that's about right , at high speeds I don't notice it only at low speeds.. But my old boat didn't have this much play.. anything I can tighten?
No, can not tighten anything to lessen it
Can change over to full hydraulic steering and get rid of all if you have the money to do so
turret_plug
I wanna chime in here..... I took my boat to the marina to try some new props, once I changed to a 4 blade prop, almost all of my steering play(or drifting) disappeared at low speed. Now..... I'm not saying that's the solution, but in researching props, I found some posts that stated I would have better low speed handling, and that appeared to be true.
I too had a little slop in the wheel though, and still do, but man..... did that prop swap make a world of difference!
I would sure like to see a vid of that.
again..... being sniped
Not really I would honestly like to see that. I have found no one ever say they can take a V hull boat with a single prop and drive straight with any kind of prop, until today. I have twin 4 blade props on my B3 and I wonder.
ilove2fixx
Actually guys it's more like 3 inches of play .. and sometimes noise from under the wheel ?
We are here but the difference between 2 an d 3 inches is mostly the same. If you want zero ply in the steering, you need to go full hydraulic
ilove2fixx
Hi guys I have a 2003
Bayliner 205 5.0 Engine with Alpha 1 gen 2
The wheel has about 3 inches of play before the rear drive starts to move ..
And when docking or slow speeds Very hard to handle .. I hope it's not something serious like that nut in the transom .. maybe bad cable ? But how can I verify ?
Bt Doctur
grab the drive and move it from side to side while someone watches the back of the boat. drive moves and steering arm does not= worn steering arm and/or pin
Ayuh,.... This has been beatin' to death, it's the Boat Operator, not the looseness of yer steerin',....
2 threads on the exact same topic have been merged,....
gm280
If there is slope in the steering, then you can check to see if bolts connections and fitting are worn or if they fit snugly. Ever segment of the steering wears. And if there is any slope anywhere, the steering wheel will have play. Because even a small amount of one connection/bolt slope is amplified (sort of speak) from the diameter of the steering wheel. So have someone turn the steering wheel while you look at every possible fitting to see if any slope exist in the fitting. If so, fix it. Could even be loose bolts. JMHO
ilove2fixx
Boat operator ? So what do you think they messed up ? Where do I start Bondo ?
ilove2fixx
So move the Rear unit ? I tried sometimes it moves and moves the steering with it.. sometimes it locks up ?
