justlakinit
Thread starter- Joined
- Jul 30, 2009
- 19
Ayuh,.... Ya rarely ever do in a boat,.... Spark plug color diagnosis is a sure-fire tool,....
So how would I go about determining that by the plugs....they all look pretty uniform.
Is the waterpump on the engine the correct rotation?
I know I'm late to this party, but I have a few tricks I can show off with, so I should be welcome... (I hope)..
First question that struck me when reading the opening post.... What revs are/were you making at WOT? If the prop's too big and overloading the engine that would very easily account for your hot spots, especially between cylinders as that is where the least water can flow...
As for determining water flow and volume, there is a 'water pump output test' in one of the manuals. You can run that to determine if the pump is supplying the right amount of water. The other possibility is a 'non-constant' water flow, but given a 1996 (Gen II) drive that is less likely, but still worth checking. The way I check is to put a section of clear hose in the incoming water line (the one between the transom plate and the t-stat housing). You MUST see a solid stream of water, no bubbles....
So, revs and solid water....
Chris.......
Is you thermostat installed like in the link below, including the sleeve and gasket?
http://www.mercruiserparts.com/Show_...NUM%2FALPHA%29
Also, are you using the original engine circulating water pump?
